Televison & Video Logo
Posted on Aug 17, 2010
How much does my older ProScan TV weigh, model PS36130FM4?
How do you hook up a Sony DVD player to a proscan tv 52 inch screen.
HDMI cable normally. Then you use the source button on the remote to display input from that HDMI Port.
Older models have 3 RCA plugs called composite Video. help videos in the link.
https://www.google.com/search?q=proscan+tv+52+inch+connect+DVD
EEPROM for proscan main bd c12090002 mod plcd5092 a- b
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How to unlcock proscan tv model # plcd5092a
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
I am shipping my tv to my new location, need to know the weight
Which model TV do you have?
The TVs in the LD-325 line are 14.55 pounds with the stand, but is 13.45 lbs without. If you have the original shipping container and all the accessories, the LD-3255VX weighed 21.83 lbs. The LD-3255AR is 23.2 lbs in the box.
The EW32S3PW with the stand is 15 pounds and 1.5 pounds lighter without the stand.
The older model SK-32H640G is 23.9 pounds with the stand. Removing the stand takes 1.4 lbs off the TV weight. When in the original box with accessories, the TV weighed 27.0 pounds.
There are a number of other models, so please add a comment with the model number and if the stand and accessories are going to be in the same box. I hope this gives you some help.
I have a 50 inch proscan and it just beeps but will not come on how can i fix it
I suspect wrong model number is listed here as this set makes no beep at turn on; older set made around 2000 but if it is your model here is some information to look at.
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Proscan-PS50700-projection-TV.htm
If not this model let me know.
4helpful
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
4helpful
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
RCA Proscan TV
I am so sorry, but that board is Way out of production. You might try service forums for Thompson or Proscan. What kind of problem is there with the old one?
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
