Dave, So you have a GFCI outlet, and a 3way switch and a 3way dimmer switch, right? First off, if you want the GFCI to protect the switches & light you will use both output terminals of the GFCI which have tape over them. The white wire (from the silver screw output of the GFCI) will go to the lights, passing through the switch boxes, but not connecting to anything. The black wire (from the brass screw output of the GFCI) will feed the first switch. Both the switch and the dimmer must have 3 terminals (plus ground). One terminal is the input/output, the other two are "travelers". On a full size switch the input/output will be on the top and the two travelers will be on the bottom (or upside down from this - the key is that the travelers will be on two sides of the switch but on one end. There will be 3 wires (plus ground) going between the two switch boxes 1-the neutral which does not connect to either switch, 2,3 the two travelers. Connect the two traveler wires to the two traveler terminals on the dimmer. The other terminal on the dimmer is the hot wire output to the lights. I hope you found this helpful. Good luck
