Question about Franke Saphira Espresso & Coffee Maker
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
Posted by bou_bou15 on
Steve Roy
    New Friend:
  • 12 Answers
Here's a link with a training video for the Flair which is on our website
Denby Dale Coffee
Franke Flair Video
Posted on Oct 30, 2012
Anonymous
    New Friend:
  • 3 Answers
Enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Posted on Dec 21, 2010
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
How to remove the lid on a franke flair coffee machine
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
Apr 26, 2015 | Franke Flair Espresso Machine with...
Why won't my Franke flair machine won't run only says please wait.is there a reset switch ?
there is no reset switch, please wait on the display indicates the machine is heating . but the sensors are not registering the temp. this means either the thermoblock/s have failed (unlikely) there are upto 4 thermal fuses mounted on the thermoblocks . this is more likely the problem. any more info required please et me know
Jan 10, 2015 | Franke Flair Espresso Machine with...
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
Franke flair malfunction 8
you have problems with the brewing group. perhaps the o-ring on the upper piston is broken.
Dec 05, 2012 | Franke Saphira Espresso & Coffee Maker
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Are there any published example beverage settings for Saeco 8p expresso vendings Eg, Recipe for cappucino & latte
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Apr 19, 2008 | Saeco Incanto Classic Espresso Machine
Franke Saphira Espresso & Coffee Maker Logo
343 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Dennis
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
