Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima wash machine has error code F05 and will not drain or spin. I removed the pump nad cleaned the internals and also the pipres leading to it, there was a small amount of debris, paperclip, hair slide etc and gunk, re-fitted and tried again but error back on, could it be the pump itself or is it time to call a costly engineer ?
Rick Ead
  • 1,998 Answers
Hello you have a jammed pressure switch on full it says so if removed the blockage have u tired replacing the pressure siwtch. You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Obviously the machine will need isolating first and the switch will need removing from the machine. it depends how handy you are if you can change brakes in a car this will be an easy task to replace hope this helps please remember to rank how this helps you and if i can help in any other way please write me back have a great day
rickead1
Posted on Aug 17, 2010
Testimonial: "Thank you for the quick response, since posting I have done a little more research and believe you are 100% correct. I"
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Wf 860 error code f05 psi switch jammed on full - machine had not emptied water. Is this faulty switch or blocked pump etc?
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Check for blockage first.
Feb 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fo5 flashes on hotpoint ultima washing machine
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution,
Thankyou.
Feb 01, 2010 | Washing Machines
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove large black hose on bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
I am getting an F-05 error
Error code F05 indicates that the pressre/waterlevel switch is jammed on full.
Remove and clean plastic filter inside hose.
Remove hose onto pump, check for obstruction here, and into the pump.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Oct 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
1,036 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
