Question about Nokia N72 Cellular Phone
My nokia n72 camera is always on an standby mode,though i hard formated it using *#7370# and *#7780#, removing the cover and pressing the camera button also does not help,,,please do help me out thank you
Posted by sjt_sharma on
Anonymous
    New Friend:
  • 50 Answers
Try to restore factory settings
Posted on Aug 17, 2010
  • Nayipriyang Apr 22, 2012
    Hi my nokia n72 in memary card insaret plese help my memory card no
Anonymous
    New Friend:
my nokia n72 camera is - 32599097.jpg Problem with the Nokia N72 Cellular Phone My nokia n72 camera is always on an standby... ' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "2849999023+2438490332+0197193999+2073327721"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); my nokia n72 camera is always on an standby mode,though i hard formated it using *#7370# and *#7780#, removing the cover and pressing the camera button also does not help,,,please do help me out
thank you
Posted on Sep 10, 2010
3 Related Answers
sonu_sehgal
bhupender sehgal
  • 421 Answers
SOURCE: Can't install softwares from my pc to nokia n72
Sir you can install files pc suit if you doesnt have pc suit you can download from{www.nokia.co.in}and these are website to download mobile software {www.mobile9.com}or{www.emobilez.com}
Posted on Jun 01, 2009
Anonymous
SOURCE: camera on standby mode nokia 6288
If the camera function will not save a picture and instead gives you the "Camera on standby" warning, but your phone is otherwise working, and you haven't used up all your memory, the problem might be with the MicroSD card. Many Nokia phones format MicroSD with, I think, FAT16, which limited the number of files that fit in a given folder to 256. You may have just filled up the camera memory folder with 256 files and you need to delete some or create a new folder on the MicroSD and use that as the new camera memory bank. Happened with my Nokia 6126 a few minutes ago and I was PISSED until i realized the quick fix.
Posted on Apr 01, 2008
Anonymous
  • 4 Answers
SOURCE: nokia 3120 classic-camera in standby mode
tyr to reload the phone software..... according to my knowledge this is not a hardware problem.... it shloud get solved by reloading the phone os...
Posted on Feb 08, 2009
How i can remove shortcuts from screen on nokia n72??
select menu
select tools
select settings
select phone settings
select standby mode
select active standby
select it as off
Jun 05, 2011 | Nokia N72 Cellular Phone
Nokia N72. The camera is not working, every time I try using it, I get the message, camera on standby, open lens cover. Please help.
you can chang your phone body.
because your phone back body is loosed so the booten can't touch.
chang body and use..........
Nov 22, 2010 | Nokia N72 Cellular Phone
I have nokia N72, camera is not working, after opening lens cover camera does not start, when i start camera going through imaging>camera, it shows the message "camera on standby, open lens cover" need...
@ above
dude im also facing da same problem( with N72)...hv u got any solution..coz i can see that ur post is almost a month old...so if u hv any solution then pls temme..
thanks..!!!
Sep 29, 2010 | Nokia N72 Cellular Phone
Not getting gprs settings after formating N72
I'm using airtel drc. I have the same problem what can i do?
Jan 29, 2010 | Nokia N72 Cellular Phone
Keypad problem
u have to change the keyboard !!!!!the circuit connections would have been distorted
Jul 22, 2009 | Nokia N72 Cellular Phone
Camera on standby open lens cover
take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Jun 23, 2009 | Nokia N72 Cellular Phone
N72 device formatting software
yes you can soft format [factory reset] your phone by pressing *7730# and entering your security code[default 12345] or weather you want to HARD FORMAT, switch off your mobile phone 1st, then press and hold 3 keys at a time star key, green dial key, and no. 3 key. then switch on your phone.
do not unhold all three key's until nokia's logo come's [hand shake] . it's done. you have to select your city. mean's your phone is virus free now.
[get backup of your contacts and messeges before formatting or you will lose your data]
May 28, 2009 | Nokia N72 Cellular Phone
Camera error in nokia n72
i think the updation of the hard ware is required,,,. if ur version id starts from 2...... . u need to update, u can see ur version id by typing, *#0000# . u can either update it ur self by using ur pc suite ( use only data cable and nt the bluetooth ). or u can consult the local nokia agency
Apr 06, 2009 | Nokia N72 Cellular Phone
How to format n72 cellphone not memory card only cellphone
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
Feb 18, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
437 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
