I had the same problem and it turned out to be the solder joints on the display panel. If you are reasonably handy at electrical stuff and have a fine tipped solder iron then you should be able to repair that problem. It took me about 10 minutes to get the display unit into a position where I could take a look at the joints. Then about 20 minutes to carefully re-solder each joint. It did however take me a while to remember how to put it back together so I'd recommend a slower disassemble and some note taking.
