Question about Casio FX-115ES Scientific Calculator
How to find the determinant - Casio FX-115ES Scientific Calculator
Posted by ajex666 on
k24674
  • Casio Master
  • 8,092 Answers
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on A SINGLE matrix are available by pressing [Shift][Matrix]. The choices are
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
Once you have created a square matrix, for example matA.
You press
[Shift][Matrix] [7:det] [SHIFT][MATRIX][3:MatA], close the parenthesis and press [ENTER].
Posted on Aug 17, 2010
I have a Element,TV ELEFT502. Have sound but no picture.How do I check for the problem and fix it.
I would follow the sound leads in from the panel. This may determine which board is simply the amplifier. Follow the video leads in; to determine the video card. If you can determine that then you might be able to determine if it is the video area or the display control. Do you have a video out port on this unit. If so cable that to another monitor and if you have a display, it would help to pinpoint the failure area. Without looking into the manual this is the best I can give you.
Mar 12, 2015 | Televison & Video
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
Civic ex does the spindle determine the size of the rotor and brake caliper?
No --- that is determined by the engineers in the designing of the car.. If you want better brakes talk to a brake shop about multiple piston calipers and different disc rotor materials but the size is pre determined .
Feb 24, 2014 | Cars & Trucks
L want to know an example of a4 by 4 matrix determinant
One example: the determinant of a 4x4 identity matrix is 1.
Use the matrix editor to create a 4x4 matrix with 1s along the main diagonal (upper-left to lower-right) and 0s elsewhere. Then use the det() function to calculate the determinant of this matrix.
Sep 07, 2013 | Texas Instruments TI-83 Plus Calculator
How can I determine the opposite direction from where I'm standing?
In order to determine the opposite direction, you should simply add 180 degrees to your current bearing.
Sep 03, 2012 | Acr Electronics Camping, Backpacking &...
How to find determinant
Given a square matrix, you can find its determinant by using the determinant function available through SHIFT 4 7. SHIFT 4 brings up the matrix menu, and 7 selects the determinant function.
Refer to the "Matrix Calculations" section in the manual, beginning on page E-57, and items #096-105 in the appendix. If you've misplaced your manual and/or appendix, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Dec 12, 2010 | Casio FX-115ES Scientific Calculator
How old is my amana whirlpool washer model number lwa50aw
The date of manufacture is actually determined by the SERIAL NUMBER on your appliance. If this is a Whirlpool, the following link explains how to determine how old the appliance is:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The 1st 2 NUMBERS in the serial number determine the week it was manufactured. Just count the weeks of the year on a calendar and this will tell you the MONTH.
The 2nd digit in the serial number determines the YEAR it was manufactured.
If you have any questions about how to determine this on your appliance, post back with your serial number and I can explain it for you. I hope this helps you.
Feb 10, 2010 | Washing Machines
Trying to determine age Whirlpool Top Load washer, LBR5232EQI
if u get the full model and seriel number i can determine that date of manufacturing,, just guessing that is somewhat of a new model number listed above prob around 2004
Feb 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How old is my Kenmore washer model 110.92389200?
The date of manufacture is determined by the SERIAL NUMBER. The following link explains how to determine this:
The YEAR will be determined by the 1st digit that preceeds the number sequence.
The WEEK of manufacture is determined by the first two sets of numbers.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Dec 21, 2009 | Kenmore Washing Machines
Whirlpool washer has stoped and service light is on
Something has happened within the unit that the computer has determined requires immediate attention. Best bet is to have it serviced. There's usually not much you can do without a method of determining the error code. The unit might have to be reset by the repair shop, and they'll determine the problem there.
Mar 15, 2008 | Washing Machines
Casio FX-115ES Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Carlo Barzo
Carlo Barzo
paulgbrandon
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
