SOURCE: black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
SOURCE: pentax sp 500 mirror return
Try setting the shutter speed to 125 and firing the camera many times. If it is going to break itself loose and start working, it should do it at 125. Then exercise it through all the shutter speeds to see if it improves. It is a long shot, but it might work!
The lubrication has probably dried out and solidified and would need to be cleaned and lubed which would probably cost between $70 and $80 so you might look around for a used body if that one won't loosen up.
CameraRepairs
SOURCE: Pentax ME Super Shutter and Rapid Wind Button won't release
Must have batterys to work shutter. Put select off auto and the shutter will work equal to 1/60th sec. for flash setting. This is a very rugged fine camera,should last for many years if taken car of.
SOURCE: Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
