Question about HP Photosmart C5180 All-In-One InkJet Printer
When printing pictures on printer paper, they come out incredibly blurry, like it dumped too much ink and it all ran together.
Anonymous
    New Friend:
This might sound silly but is the paper in backwards? If an inkjet printer prints on the back of photographic paper looks just like you're describing.
Posted on Aug 19, 2010
Testimonial: "That WAS silly, and that happened to be it! Thank you SO much. Even HP, who wanted $35 wouldn't have come up with that!"
Anonymous
    Scholar:
  • 103 Answers
Clean the copper contacts of the cartridges & cartridge slots with a lint free cloth moistioned with distilled or normal tap water.And shake cartridges well before installing.
Posted on Aug 17, 2010
Blurry photo print-outs
Hi Ashley
try printing a "nozzle check" and if any colour stripes look incomplete, "clean" or "deep clean" the printhead until you get a good result. You can find the cleaning and test utilities on "Maintenance" page in "Printer properties". Also make sure you're putting the paper in right way up.
Dec 23, 2013 | Canon PIXMA Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
I have a Canon i9900 printer. I have used the daylights out of it. Can printers start to print blurry if they are wearing out? My prints look fine at 100% on the monitor, and when I print the picture it...
Problem : Ink does not eject properly or Printing is blurred or Colors are Wrong or White streaks appear.
Cause 1 : Ink tank is not seated properly or the ink tank is empty.
Action : Check that the ink tanks are firmly seated in the print head and reseat them, if necessary.
Check that the correct ink tanks are installed and that they are in correct order.
Check to see if all the orange tape has been peeled off. If a part of the orange tape remains, remove it thoroughly.
If an ink tank is empty, replace the ink tank.
Cause 2 : Print head is misaligned.
Action : Align the Print head.
Cause 3 : Print Head nozzles are clogged.
Action Print the nozzle check pattern to check for uneven ink output.
When specific color is missing from the nozzle check pattern, clean the print head.
Cause 4 : paper is not loaded with the print side up.
Action : Checl that your paper is loaded with the correct print side facing up.
Note: Follow the instructions packaged with your specialty media for loading and handling.
Cause 5 : Incorrect paper type.
Action : Windows : On the Main tab of the printer driver, confirm that the selected Media Type matches the paper loaded.
Mac : In the Print dialog box of the printer driver, select Quality &
Media from the popup menu, and then confirm that the selected Media Type matches the paper loaded.
Cause 6 : Glossy photo paper other than the Canon specialty media is used.
Action : Select Other Photo Paper from Media Type. It may resolve the problem. Load one sheet at a time and remove each sheet as soon as it is printed.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon i9900 InkJet Photo Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply [email protected]
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
PRINT IS BLURRY
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Mar 26, 2009 | Xerox Phaser 8550DT Thermal Printer
Color ink is TERRIBLE!
I think you are printing on the wrong side of the paper. Try flipping it over when you put it in.
Dec 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Pictures printed from computer are pale and faded
Are you using photo paper to print your pictures? If you print your photos on regular paper the ink on the photos can bleed or run together in the paper fibers. Try using paper made to print photos and see if that helps
Dec 05, 2008 | Office Equipment & Supplies
Line down the right stide in the megenta area of the self test and blurrred print on the right side
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Oct 31, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
144 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
