Question about Car Audio & Video
I have a 2001 dodge ram, when I connect either the ground wire, power wire, or both from the cd player I am installing, all of the dash gauges quit working.
  • 239 Answers
Make sure your not connecting the power wire to the power for the gauges here is the wiring diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Posted on Aug 17, 2010
6ya staff
SOURCE:
I have a 1998 dodge ram 1500 I am trying to put a aftermarket radio in but I can't figure out what the ground wire in the dash is
ground wires are normally black
get a multimeter and set it on ohms resistance
put one end on the wire and the other to metal ground
if it is a ground wire the gauge reading will be all zeros as that indicates a circuit
Oct 02, 2016 | 1998 Dodge Ram
Kenwood install dodge ram now subwoofer not working
does the stereo have sub settings they could have it turned off. did you connect the remote wire to the amp(its used for turning on the amp or for powering a power antenna usual a blue wire coming from the head unit). also check the fuse on the amp. hope this helps.
Nov 29, 2014 | Kenwood Audio Players & Recorders
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
Malfunctioning gas gauge in 1993 dodge Ram 250
A mechanic would check for power and ground at the connector for the gas tank. Grounding the wire from the gauge should make it move.
Aug 24, 2012 | 1993 Dodge Ram
The dash lights and gauges in the dash are not working properly, gas gauge will say 1/8 and be empty. Periodically they will all fall to 0 on all gauges and stay there till you smack the top of the dash...
Hello it sounds like a ground or connection problem to you dash cluster. I would pull the front driver side dash board appart and unscrew the the instrument cluster check wiring for being loose or corroded at the plugin. if that checks out good no corrosion the instrument cluster itself might have a problem. I seen the instrument cluster go bad before that is probably it.
Mar 01, 2011 | 1997 Dodge Caravan
I have a 1999 Dodge Ram, I just replaced the
Why this isn't a total solution, one resource I've used many times when it comes to electrical diagrams is http://www.the12volt.com/. They have all the diagrams and "audio experts" there that might be able to tell you specifically the color.
Jul 05, 2009 | 1998 Dodge Ram 1500 4WD
More gauge questions
you may of pinched or cut a wire while installing the cd player. or possibly when hooking up to power, you plugged into the power for the instrument cluster
Feb 20, 2009 | 1999 GMC Sonoma
My 2001 dodge ram 1500 5.2 v-8 check gauges light comes on and the battery gauge is not charging half way and as soon as I drive it , the gauge goes to none charging but I can drive it and it doesn't give...
on the alternator did you put the little washers where the regulator bolts on back of the alt they must be tight and also the ground cable from the battery to the alt bracket must be tight and grounded sounds like a loose connection
the washers go between the alternator and wires coming out of the harness and the alt also it probalbly goes dead occasionally when you crank it up
Feb 02, 2009 | 2001 Dodge Ram 1500 Truck 2WD
I have got a kenwood cd player but can,t install it into my vauhall corsa because i need a seprate battery 15amp yellow cable to run from the battery supply to connect up to a cable attached to the radio...
You can test one of the wires from the harness connector for a contant +12v with a test light. They are sold at your local auto parts store for less than five dollars. The harness connector that i'm talking about is the harness connector that originally connected to the stock radio. All of the connections needed to install a cd player are all on that harness wire. The test light is simple to use, all that's needed is for the alligator clip to be hooked to ground. And from there, you can determine from tapping which wires are for the power supply. The power consists of three or four wires. They are ground, +12v ignition, +12v constant, and if installing w/ an amplifier, the remote. This is the usual place most people connect the wires for a new head unit.
Nov 21, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
240 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
