Question about Razor E300 Scooter
Razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
Posted by davereid41 on
  • Anonymous Mar 29, 2014
    I hear a clicking noise but my scooter does not go. The motor is fine and the battery is also fine. But I do not know what the problem is.
    The motor and battery are fine, they work. But I hear a clicking noise and the scooter does not drive.
Anonymous
    New Friend:
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
  • tan tran Dec 08, 2012
    did you solve the problem with the new charger?
manningc1999
    New Friend:
I have the same problem, I think it's the battery.... See if you can get a new one
Posted on Jul 31, 2012
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Oct 18, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Mar 19, 2014 | Razor E300 Scooter
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT...
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Mar 08, 2014 | Razor E300 Scooter
E300 , replaced both batteries , now charger light stays green although just plugged in to new batteries for first time. What is it now ?
This is most likely the control module.It can cause this.I had it happen before :) hope this helps.Buy one at www.razor.com or on ebay.
Feb 06, 2014 | Razor E300 Scooter
E300s razor
Note the charger doesn't turn itself off. It will only signal batteries are charged. You can overcharge these batteries by leaving them on the charger for too long. Suggested by retailer is two hours maximum.
Any case, Jackson Mack is correct on all counts there.
If the light is green on the charger, and the scooter still doesn't go, there might be some other issue besides the batteries themselves like loose wiring, fuse switch, etc.
Nov 12, 2013 | Razor E300s Electric Scooter With Seat
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
I was given a Razor E300 and was told that the only thing wrong with it was it needed a new charger. Well, I got the charger and it states the razor is charged but the razor still doesn't work. Any...
You have to make sure that the batteries are still good.
Take a volt meter and read the levels that the batteries are producing. If the levels are too low, then your batteries may have sat, unused, for too long. SLA (Sealed Lead Acid) batteries will generally lose their charge holding capabilities if you leave them in storage for too long without charging them.
YOu can get replacement batteries at this online Electric Scooter Parts Store:
http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
-Jackson
http://urbanscooters.com/
Oct 16, 2010 | Razor E300 Scooter
We have A 300 razor battery scooter but do not have the battery pack or the charger.
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Jul 10, 2010 | Razor E200/300 Electric Scooter Battery
Razor E300 Scooter Logo
4,025 people viewed this question
Top Razor Toys Experts
gbob59
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Razor Toy Expert? Answer questions, earn points and help others
