SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
SOURCE: Frigidaire ftf630as0 Front-Load Washer TUB DOESN'T WASH OR SPIN
How old is your machine? Mine was doing the same thing. After doing some research online (and a visit from a Sears technician), I found out that the bearings died on on the drum. The Sears technician told us it was a combination of the type of soap being used (non HE), and the amount of soap being used per load that contributed to the unit's failure. I wish someone had explained that to us 7 years ago when we bought the machine. Appearently there are enzymes in the soap that will eat away at the rubber washer that protects the bearings. There are less of these enzymes in HE laundry soap, thats why it's recomended for front loading machines.I think the HE soap will still eventually cause this machine to fail, but it would take a little longer than 7 years (maybe 10 or 12). By then it's probably time to by a new machine anyways. We bought a new machine because it would cost over $500 CND to get the old one fixed. We ended up with a Frigidaire Affinity (FAFW3577KN).
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
