Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Looks like a spider web on my screen how much to fix??? pls itsa lc-37gd8e
Posted by tommytittlem on
Chi Chu
  • Sharp Master
  • 8,457 Answers
Not fixable or worth fixing.The LCD screen panel is broken or damage,will cost the same to replaced the LCD screen same as a new tv.The LCD screen panels or any screen panels for that matter.The tv screen panels are limited produced by the the tvs corporations.Tvs are damages or boken screen panels are only can be salvage for it electronic boards for parts,not worth as a whole tv anymore.
Posted on Aug 16, 2010
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Wii remote hit screen. can it be fixed
if it looks like a spider web on the screen, yes but the repair cost will be more than buying a new tv.. sorry any damage to the screen on a plasma or lcd normally costs more than the tv. you can however try to sell it for parts, such as power supply etc and also the remote
Sharp Aquos LC-37GD8E ... IM VERY SOORY TO BODER YUO BUT MY TV WONT START AT ALL SERIAL 610414045 thx
i find that my aquos lc37gd8e has no signal between 5pm and 6.30pm but my other tv is fine it also switches itself of somedays at 9.30pm have trided retuning this has not helped can you help?
Spider web screen..
yes lcd is broken. repair is usually around 120.
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
LCD screen V-1003
It needs a new LCD screen and that would cost $85.00. TC
2answers
SONY WEGA SCREEN
take the back cover off and vaccum them out, then dust it. If you can take it outside, compressed air does the fastest job of cleaning out dust.
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
