SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
SOURCE: Water is dripping from the front of the unit.
have the unit charge checked it could be low if not low then the coils might be restricted either by dirt or finns dammaged or check for any kind of air flow restriction
SOURCE: We have a Fujitsu Halcyon
Hi, first of all, you can get a replacement filter by contacting Fujitsu on (973) 575-0381, (866) 952-8324 toll free and you will be told the nearest Place around you where you can get it from.
Secondly, your AC not cooling might be as a result of a clogged filter, which is not pulling good air flow. If that is not the problem, it could be that the refrigerant is low, coils could be dirty, or a thermostat problem.
But i think the red light signifies that you need a new filter..
Take care
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
