Question about Samsung LN46A650 46 in. LCD HDTV
The samsung ln46a650 will click continously when triing to turn on and the red light just keeps blinking.
Posted by lillideer on
Anonymous
    New Friend:
  • 16 Answers
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has greed to fix this as a "courtesy repair".
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Posted on Aug 21, 2010
Edward
  • Samsung Master
  • 3,459 Answers
As others pointed out In most cases it is the capacitors in he power supply section that have gone out.
Common symtoms are
-shuts down
-takes a long time to come on
-relay clicks
-dead set
You can get capacitors online or you can get a complete kit with instructions and support from www.TvRepairKits.com . Its a failry easy DIY fix.
Posted on Dec 15, 2010
  • Sp Gupta Apr 16, 2015
    Do they supply repair kit for main boards too?
Anonymous
    Problem Solver:
  • 11 Answers
Upper right corner of the power supply board
Look for bulged tops on:
CM851 1000uF 25V
CM852 1000uF 25V
CM854 1000uF 10V
CM855 1000uF 10V
Make sure to install new capacitors with correct polarity
Posted on Sep 10, 2010
    Top Expert:
  • Samsung Master
  • 76,407 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Posted on Apr 16, 2015
Sp Gupta
  • Samsung Master
  • 727 Answers
Hi Friends,
Some time back I repaired a 46" Samsung LED TV with continuous relay clicking and blinking red LED. Power on 5V line was short with the ground. I had to replace the main board in that case. I hope this will help.
Posted on Apr 15, 2015
Tv not coming on keeps on flasing the red standby light
you have a 1 year frm the date of purchase mfg warranty. if not you will have a tech look at it and tell you the video board might be going out.
Sep 21, 2010 | Samsung LN46A650 46 in. LCD HDTV
Red and green LED continous blinking when printer is turning ON..........
sounds like a jam or gear/roller problem as it sounds like it never boots up fully/passes boot tests. Have you tried looking for the light codes in the manual? You can also go to Samsung's site and pull down the guide.
Aug 04, 2009 | Samsung ML 1610 Laser Printer
No Audio & Video red light blink continously.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
May 29, 2009 | Sony KP-57XBR10 57" Rear Projection...
Samsung Ln46A50 won't trun on
You need to get service for replacing the main board.
Nov 20, 2008 | Samsung LN46A650 46 in. LCD HDTV
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A [email protected]
Jul 16, 2008 | Epson LX-300 Matrix Printer
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
May 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung LN46A650 46 in. LCD HDTV Logo
1,669 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
