Acer TravelMate 529ATX Notebook Logo
Posted on Sep 30, 2017
Browser will not open
Hi
I have a toshiba laptop. I have been using it for the last one year. Recently a problem developed. Although my broadband DSL connection gets connected my browser wont open. I am greeted with the dialogue 'cannot find server' all time no matter what browser I use-IE, mozilla or any other.
Pl help me.
Mihir Choudhury
  • daveohr May 11, 2010
    Are you connedted directly to the modem or through a router?
  • Anonymous May 11, 2010
    Have you recently uninstalled/installed any applications that have firewall capabilities?
    Have you tried the same connection with another computer?
    What is the operating system?
    Have you run any virus scans on it?
    I can help you with this i just need wayyy more info :P
Betty Sue Walker
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 30, 2017
Betty Sue Walker
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
964
Points
19
If all fails you could try setting it back to factory!
5 Related Answers
Anonymous
  • 1913 Answers
  • Posted on Nov 11, 2008
SOURCE: Acer Notebook Wireless connection
no check your windows firewall.
and antivirus firewall
also check in internet explorer.
cpenzes
DEKR
  • 1102 Answers
  • Posted on Jan 16, 2009
SOURCE: acer aspire netbook
have you checked control panel internet connections to see if your connection is even showing in there
If it is I would right click then status and then repair
if that does'nt help then you may need the driver updated
Anonymous
  • 32281 Answers
  • Posted on Oct 01, 2009
SOURCE: acer aspire 9410, cannot connect to the internet using dial-up
According to ACER your model supports a modem, Lan and a wireless LAN These specs are attached for you your info :-
Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet (LAN) Gigabit Ethernet, Wake-on-LAN ready WLAN: Intel PRO/Wireless 3945ABG network connection (dual-band
tri-mode 802.11a/b/g) Wi-Fi CERTIFIED solution, supporting Acer
SignalUp wireless technology
Connecting to the Internet using a wireless or a LAN DSL or cable connection is a lot faster than dialup, and you cannot compare this type of internet connection with a dialup Internet connection as they are different technologies.
To trouble shoot your modem follow these instructions :-
To check the modem connection/phone line, connect a phone to the modem's phone line and see if you get a dial tone on this line and you can dial out on this line. If it is OK then connect the phone line back into the modem and see if you can connect to the Internet using your dial up connection.
If it doesn't work click on Control Panel - Phone and Modem - click Modem tab - click Properties - click Diagnostic tab - click Query Modem and if you DON'T get a list of modem responses then either the modem is faulty or the modem driver needs reinstalling.
ishaquekvm
  • 212 Answers
  • Posted on Nov 01, 2009
SOURCE: Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Testimonial: "Many thanks, slight difference in the names on the windows I had to open but it got me on the right track and problem solved."
Anonymous
  • 218 Answers
  • Posted on Apr 18, 2010
SOURCE: No browsers will open at all. Aspire One AOA110
The Default gateway settings seem to be the problem. Try the steps below:
1.Click Start 2. Click Control Panel 3. Click Network Connections 4. Then click either the Local Area Connection Properties Click TCP/IP Properties, make sure that IP address and DNS are set to "automatically obtain." Click the Advanced button and make sure that nothing is entered for Default Gateway and on the DNS tab
repeat from step 4 for wireless connection properties also, if you use a wireless connection. You may also switch off the modem (and router if you have one) and turn it on after a few seconds. Reboot the computer.
Good luck
Grand Canyon Tech
Grand Canyon Tech
