Its the dryer fan thermostat, faulty. the unit will turn off if it does not read the thermostat and that's why you have a code. I would say its safe to use but would have the thermostat replaced. here is a video on how to replace the heater. https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-f13-error-on-a-washer-dryer-hotpoint-indesit and these are the sensors. https://www.partmaster.co.uk/washing-machine/wdd-960-k-uk-f069442/thermostat/catalogue.pl?shop=hotpoint&path=52516&model_ref=967828&refine=thermostat, hope this helps.
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
SOURCE: error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue.
God Bless.
SOURCE: aeg electrolux error message E20 has just flashed
it might refer to any
blockage in the water supply. So cleaning the pump could primarily resolve this.
but it might also be a blockage in the soap tray (when available), the
tap or the hose attached to the tap or the air-gap or any water control structure. but most of the times, it is simple blockage of pump. just pull out the manual, remove, clean and replace the pump. this will solve your problem.
cheers
