Take out the lower rack and remove the lower washer arm. There is a plastic bearing that looks like the picture below :-
This part can wear through and no longer have a lip around the top of it. If this is the case, it will cause the water to push out in waves and water will come out the bottom of the door. Otherwise, just replace the door seal.
Note - if it leaked when it was draining then that has nothing to do with the tub or the pumps or anything like that. You have to have a bad drain hose if it's leaking only during drain. It's probably best to uninstall the unit and watch it to see if you can find exactly where it's leaking from to confirm but if it leaks when it drains there has to be something wrong with your drain line itself.You could try the spray arm gasket first and see if that works. If not, you could look into the drain hose/line, hopefully it's not that.
Good Luck!!
Thanks!!
