Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
How do i rekey the deadbolt to fit the doorknob key?
Posted by lindseyaddym on
leslie
    New Friend:
    Problem Solver:
  • 10 Answers
At Factorylocks.com you can order a cylinder to match B series deadbolts On the shopping cart page there is a place to put the 5 or 6 digit key code. The here is a link to deadbolts on the factory locks site Schlage Series Deadbolts or call us if you have questions 877-345-6257.
Posted on Nov 21, 2014
Anonymous
    New Friend:
  • 82 Answers
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Posted on Aug 15, 2010
Rekeying house door lock
rekeying depends on the specific brand of lock you have.
The easiest solution would be to replace your current locks with the same brand. Figure out how many of which locks you want to change, ie: deadbolts, entry knobs, etc. and buy matched sets from your local hardware store. They are marked with a key code on the box...make sure they match if you want the keys to be the same.
Nov 16, 2014 | Locks & Locksmithing
I have a schlage deadbolt without the original key. is there any way to rekey without having to take cover plate off top of cylinder?
yes call lock smith for about thirty dollars they can make you a key right on the spot without removing lock.
Jan 05, 2010 | Electrical Supplies
Key won't turn deadbolt
Try using your smartkey to "rekey" the lock to the original key... there's really no reason to buy the smartkey system unless you change locks alot... they are meant for the apartment industry more than anything I believe... in any case, the smartkey system allows you to rekey the lock without removing it from the door... so, use the original key and use the smartkey to rekey it or select a different cut and key it to that key... should solve your problem.
Last resort... take it back to HD for replacement.
Sep 09, 2009 | Kwikset Locks & Locksmithing
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Jul 20, 2009 | Kwikset Locks & Locksmithing
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Need to have a master key for all locksets
Any locksmith can rekey the locks to a single Master. Some make house calls, but it costs less to take them off and take them if this is feasible.
Mar 01, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Rekeying kwikset locks
Sure. You need to install the key in the cylinder and keep it turned so the pins are on top. Then you install the pins one at a time in each hole until all the pins fit level with the top of the cylinder, You will probably have to re-arrange the pins once or twice to get the correct length in the correct hole but once all the pins are level you're home free.
Sep 30, 2008 | Locks & Locksmithing
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
355 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
