Question about Averatec 7171000100 Keyboard
Suddenly my Averatec won't start
Turned on my Avertec 3200 one morining and it would't start. Pushed power on, nothing, but I did hear faint high pitch sound. Tried sleep function key, nothing. Green light is on. Know it isn't power cord or battery, have two Avertec's. Is this hardware problem? I have an Averatec 7100, about 2years old. Sometimes it will start, boot up completely, wait about 5 minutes then shut off. power cord is fine, battery 100%, other times it won't come on at all. searching for answers. any solutions let me know. I have no idea how to resolve this problem without sending it back. thats what best buy [email protected]
Posted by bkon on
  • claylover23 Jul 31, 2008
    I have/had the same problem, only when my started up it would start up for two seconds... so I bought a new battery and nothing... same thing.. i dont know if it's the adapter or what. If anyone can help... PLEASE let me know.
    [email protected] is my email.
    Thanks!
    -Jenn
3 Related Answers
Anonymous
SOURCE: Disassemblyan Averatec 7100 how to,...
it comes apart .. take the screen off and take it apart fromthe top. I did it and it opens everything up.
Posted on Mar 05, 2008
Anonymous
SOURCE: Suddenly my Averatec won't start
http://www.power-jack-repair.com/averatec.html
amazing guide for how to fix this problem, hope it helps you fix your computer.
Posted on Apr 13, 2008
Anonymous
  • 64 Answers
SOURCE: suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Posted on Aug 07, 2009
I have an Averatec 3200 xp home edition. It was a gift. All that came with it was the power cord. How do i reset factory settings?
If laptops do not come with an installation disc, sometimes there is a setting in the BIOS which will allow reseting to factory settings. When the computer is first turned on, it will usually provide a specific key to access the BIOS or setup screen.
Mar 06, 2011 | Averatec 3200 Notebook
Avertec 2300 will only power on to a black screen and says Read disk error, press control alt, delete to reset, but when you do this the same thing apears over and over, Will not take any disk windows or...
Sorry, a Read Disk error means the disk is dead or dying. At a minimum, you have to reformat it and reinstall Windows. If it doesn't reformat, then you need a new hard drive.
Oct 27, 2009 | Averatec 3200 Notebook
Suddenly getting boot failure message averatec 3200
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
Avertec 3200 won't reboot, white screen says NTDLR is missing
Ooops, if ntldr is missing, it means your operating system is dead. You should reinstall windows from cd. Must get into Bios to select first boot device as Cd and then press f10 and yes. When you start your lap it says you what key press to get to Bios or boot menager.
Mar 26, 2009 | Averatec 3200 Notebook
Hook up Avertec 3200 to Sharp Aqueous TV
After I found the manual somewhere on the internet, I realized that it is already available here. (Lucky you!)
I could not find a specific manual for your Aquos TV (which model?). Look into your manual, and see if there is an option to connect via VGA of HDMI for video
If you want to use your TV speakers, it depends what audio input options you have on your TV. You might need a cable like this:
The red/white connectors into your TV, the 2.5mm plug into your computer.
Jan 11, 2009 | Averatec 3200 Notebook
Laptop Averatec 3200 PC Notebook
Try having the problem devices turned on and plugged into the USB port(s) and then start or restart your PC.
This should cause Windows to recognize them and install drivers if available from its library.
It may also ask for an installation disk if it cannot identify the device.
Jun 30, 2008 | Averatec 3200 Notebook
Avertec 3200 notebook
remove the cmos battery from the board and replace it again!!
Jun 14, 2008 | Averatec 3200 Notebook
Power jack problem
You didn't mention the model so here's some information that might help you with the dis-assembly process. You might want to use a digital camera to document your dis-assembly. The pix will make it a lot easier to do the re-assembly. PS, when you finally get it back together and working, invest in a good CRD (Cable Retention Device) to take the strain off the pin and keep you from having to do the job again. I use and recommend this product.
Apr 24, 2008 | Averatec 3200 Notebook
It could be your Power Supply or your CMOS Battery is dead. For Power Supply, you can test by try to connect your Power Cord without battery to see for any PowerPush. If it is still not on then you can check your CMOS Battery for any failure by test the good one from other similar laptop since you had two. I hope this help.
Apr 22, 2007 | Averatec 3200 Notebook
Where is the cmos battery on the Averatec 3200
I can't find step by step instructions for dismantling your laptop (I found them for a Toshiba), but in general the CMOS battery on any PC is on the motherboard (this includes laptop motherboards). You'll have to take the system apart, including taking the keyboard out, etc. etc. to get to it. Take a look at how a Toshiba 6100 is taken apart for an example: http://www.irisvista.com/tech/laptops/Toshiba6100/Toshiba_Satellite_Pro6100_dismantle_1.htm It's not for the faint of heart so I'd recommend taking it to a local repair shop ...
Apr 14, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
81 people viewed this question
Top Averatec Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
