When I try to install the coby dp 151 it says: cant find photoviewer or program that owns it. the program will exit. ?? confused
Posted by tmatos1122 on
YourZEN
  • 820 Answers
The error you describe, is also mentioned in the Setup Guide for the DP151.
When you connect the Key Chain to the USB port of your computer, on the Key Chain will prompt the message to select: USB charge or USB update.
For proper function of the Chain Key:
0) Before connecting the Chain Key, have the Photo Viewer software installed:
You need adminstrator rights to perform installation of programs.
Install the photo viewer from the CD or download this program
from the Coby support site:
> enter cobyusa.com in the address bar of internet explorer
> enter DP151 in the Product Search bar
now all support for the Chain Key will show
> run the DP151_PhotoViewer zip file directly or save the zip file onto your computer, unzip and run the setup.exe file later
1) Connect the Chain Key and Select USB update on the Chain Key.
Again, to be able to update, you need adminstrator rights.
2) Run the Photo Viewer on the computer.
Posted on Aug 15, 2010
I have placed photos from my pc to Photoviewer 2.3 but when I try to download photos to Coby DP-152 I just get a download failed message. Why? What am I doing wrong?
uninstall photo viewer,then reboot your computer,install the cd with photoviewer on it,(for windows,not mac),next reboot your computer,now,connect your coby to the computer,wait until it is recognized,double click on the photoviewer icon on the desktop screen,let it load,
Coby DP 152 Instruction Manual
May 30, 2015 | Photography
I have not used my Photo Viewer for a few months. Was working ok. But now Software would not respond when I plugged keychain in. Tried many times. Uninstalled PhotoViewer Software. Re installed same....
The program is corrupt. Uninstall it, delete all remaining files and folders, run a registry cleaner, defragment, download a new installer and install it again but in a different location.
Or you could just install a much better photo viewer   http://www.irfanview.com/
Aug 03, 2010 | Computers & Internet
Installation on XP for Coby DP-151
chyeck for the program in control panel if it is installed then check the installed program in all programs n then configure it using the recommende setting
Jan 16, 2010 | Computers & Internet
Program will not run properly
I found this on an Amazon review. I hope it works for you:
1) Install the software on the CD (although the application won't open just yet)
2) Plug in the usb cable into the pc and the keychain and wait a minute (nothing happened here for me)
3) Unplug the cable that goes into the keychain, and then plug it back in. On the keychain screen, an option menu should come up that allows you to select either to power the keychain or to update the keychain via usb. Select the update option. (Note that drivers might install before this or maybe it found the driver I downloaded at the coby website?)
4) Now that you have selected the update option, you can now open the program that was installed off of the cd. Select the pictures you want, move them over, and then download them to the keychain.
Dec 24, 2008 | Computers & Internet
Can't use my Coby DP - 151 Keychain
in the search box under the program list that pops up when you press the windows icon in the LH of the task bar , type in coby dp and enter
if it is in the computer a list will come up
click on that and that gets you to the path
high light and click to open
Dec 24, 2017 | Sony Cyber-shot DSC-W55 Digital Camera
Software won't install coby photo viewer key chain
You need to make sure the usb cable is in all the way to the viewer. You have to push it hard. No silver showing. Always need the viewer plugged in first before starting the viewer program. After that it is pretty simple.
Nov 14, 2008 | Computers & Internet
Copy DP-151 Photo Viewer software does not work.
You have to push the USB cable into the keychain until it pops. Push it in hard! I thought mine was all the way in because the keychain lit up, but it wasn't.
Jul 08, 2008 | Audio Players & Recorders
Installed software and when try to run it gives error:Can't find any photoviewer, or another program owns it. The program will exit. Running XP Home
When you plug it in look on the device screen and change it from Charge to Update. This will allow the driver to install. After you can run the photoviewer software (I had to try twice, probably because the driver wasn't installed yet).
Apr 19, 2008 | RIM BlackBerry Pearl 8100
Trying to download drivers for 151 coby key chain photo says file to big
download all software and guides from this link
click on downloads to display photoviewer and drivers
Mar 30, 2008 | Cameras
Computers & Internet Logo
497 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
