Frigidaire FAC126P1 wall/window Air Conditioner Logo
Question about Frigidaire FAC126P1 wall/window Air Conditioner
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls in my house. Please help with a fix for this awful awful design.
Posted by proden22 on
Anonymous
    Sergeant:
    Champion:
  • 215 Answers
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Posted on Aug 15, 2010
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
1helpful
The water drainage hole on my fridigaire ac is only 2 inches from the front of the unit, thereby sitting on the sill itself and pouring water onto my sill and down the inside of the wall. Is this a...
Sounds like a defect to me or a hole has rusted through the condensation pan.Generally, all drain holes are at the rear of the pan. That's why the rear of the unit is supposed to tiled down 1/4" to 1/2". That way, the water flows to the rear of the pan.
I hope this helped you and thanks for choosing FixYa.
What is the proper way to drain my model 206 for winter?
It should be piped and valved (when first Installed) for yearly draining procedure, but you do need to knowthat in oeder for proper drainage, you need to allow an air intake point so the water can get out. This air-in point is usually near the top of the unit or piping maze. Goodluck, Macgivor
4helpful
Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
6helpful
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
3helpful
Samsung J845 front loader washing machine. Error
Hi
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
4answers
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
3helpful
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
7helpful
2answers
Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
39helpful
5answers
Leaking water
I had exactly the same issue after using it for a couple of months.
I fixed it by removing the left panel (the one with the grid) (6 screws and pull the panel down).
There is a small white tray in the mid section toward the back of the unit. the top drainage hole is right there and in my case was completly blocked with wet lint.
!!! the fins of the radiator are extremely sharp...
Top Frigidaire Heating & Cooling Experts
David Shaub
Jaime Hernandez
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
