This means that your deck is going into protect mode often this problem is due to poor installation and or overheating of a older product, so if it is just old buy a new one if you installed it get it professionally done ifyou had it professionally installed go smack your installer and tell him to do his dam job
SOURCE: display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
SOURCE: Kenwood car CD player not working
This means that some one has entered the wrong security code more than 3 times. time to take it to a dealer
SOURCE: MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
SOURCE: lMy JVC CD player reads
Try checking your speakers and speaker wires for shorts and/or grounds. Make sure none of your speaker wires have any bare spots. If your speakers and speaker wires are fine, you may have a bad internal output ic inside of the deck.
Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when . These are generic instructions. If you get stuck or need
specific instructions for your car, please get back to me with model, year info.
