SOURCE: PANASONIC PVG59
Hi, I have a Panasonic NV-DS38 which does exactly the same thing. I spent £160 in a repair lab to fix a year ago and now its doing the same thing again. V annoying. But I have found its something to do with the loaded tape. Try a different tape or try ejecting, powering off, powering on and reloading the tape. Its a workaround rather thasn a solution but have a go and let me know. Martin
SOURCE: Push the reset button,PANASONIC NV-GS11
My NV-GS15 asks me to push the reset button every time I turn it on
SOURCE: where is firewire slot on panasonic mini dv nv-gs30
Usually it's inside the access door on the side. It looks kind of like a usb cable connection.
Jill
SOURCE: What leads do I need to connect my Panasonic NV-GS30
There is an optional cable available for your camera called the VW-CD1E that will make use of the firewire (DV) port on your camera. You will also need to have some sort of a video capture program like Adobe Premiere so that you can download the video from your camera and then edit or display it. You should be able to order the cable from any Panasonic retailer. The better electronic / video stores will probably have it in stock.
