Try the default password 000000. If that doesn't work, try this:
Here's what I found. -Download Hiren's Boot CD 9.8 -Boot to it and boot into MiniXP -After it loads, open Notepad and minimize it. You'll need it later. -Open the Hiren's Boot Menu app and scroll to the "Recovery" menu, then select Partition Find and Mount. -Select your physical HD and do a Normal Scan of the drive. -Once you find the hidden partition (approx. 5Gigs), mount it as any unused drive letter. -The AIMDRS.DAT file will be on the root of the drive. Now drag that file to Notepad that you opened earlier. Here's what it should look like: [MyData] PD=xxxxxx HT=
whatever password you used should be displayed beside "PD".
Write that password down, reboot to Normal Windows and run the recovery managment tool.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
hi, 1. press menu button 2. select setup 3.go to orientation (This sets your image for your type of projection. The options are: desktop front projection, ceiling rear projection, desktop rear projection, and ceiling front projection.) ok,
After you click print a new window opens, click on printer preferences where you choose paper size and orientation, etc. open the different tabs at the top until you find mirror image printing, don't forget to set it back cuz all will be in mirror...
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps Sincerely, Michael Scott
Good evening Paresh this is viswanath Don't worry I can salove UR problem
First U go to Open Menu & go to Zoom option, select Zoom Function and press 30 sec
sercice manual is open Adjest UR settings & save it,turn of ur monitor.
