Computers & Internet Logo
Question about Cnet Computers & Internet
What is remote access server?
Posted by derril on
tom sh
  • 1,141 Answers
A server that is dedicated to handling users that are not on a LAN but need remote access . The remote access server allows users to access files and print on the LAN from a remote location.
Posted on Aug 15, 2010
2answers
What software should I use to bypass my university internet restrictions?
If the games are in fact, "yours" then you can configure your game server to publish on the normal HTTP port (80). Then, you will have no trouble at all.
I hope this is helpful,
--Robert
Does remote access is secure?
In general, VNC connections over the Internet are not secure, since the traffic sent is not encrypted in any way so it is not advisable to use them for sensitive data.
What is remote access server? And what does it enables me to do?
Remote access allows you to connect your PC from a remote location using the Internet. The entire working environment of your computer is brought over the wire to wherever you are, eliminating the need for synchronizing between laptops and desktops.
1helpful
3answers
Windows home server remote access - cant get it to work
It's probably not about RDP. I think we are talking about the homeserver remote access that allows you to up/download stuff to/from yourshares, run the server console or remote control a workstation in your homenetwork from outside (from the internet).
The whole procedure is a little complex. In short, you have to:
- start remote access in the WHS console (settings - remote access)
- create and configure a dyndns domain name (or something similar) to find your server from outside
- configure the user profiles to allow remote access. They need to have "strong" passwords.
- forward the port numbers 80, 443 and 4125 to the servers IP address on your internet router.
- forward the port 3389 too, in case you want to use the RDP protocol to access the servers remote desktop.
That should be it.
If you have several routers in your net, you have to forward the ports from the first one to the second and from there to the home server.
Since we don't know where exactly you are stuck, you should post a little more information.
Hope this helps.
Remote access for 3com firewall network
dial in using the vpn to the windows 2003 server network and call the remote desktopof the server using the netbios name or using the local ip address
2answers
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
1helpful
How to limit remote access to a Termional Server
The best way to do this that I've found is to restrict the access via your firewall. Typically, Terminal server is listening on port 3389. So you would create rules in your firewall that will block any traffic to this port from IP addresses or subnets that you don't trust. While you're at it, you should shut down all other ports to everyone if you're not using them.
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
