Question about HP Deskjet 2360 InkJet Printer
My printer cannot print my printer is in backup mode
Posted by alcuiz_2006 on
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
Zebra 90XiII - sometimes when adjusting the tear off position using the arrow keys. The printer (motor) doesn't move the label media in/out. When it does actually move the label media to the desired...
Print a configuration label and see if it is in the correct mode - tear off mode. If it is in rewind or peel off, then the label is not suppose to come out to the cut bar, but stop under the print head and not backup.
If you want it to align with the cut bar make sure that the driver is set for tear off with backup enabled. The printer driver in the software will override the printer setting and change it as soon as you send a print job.
Dec 02, 2010 | Zebra 90XI II Printer
My printer screen says
The ink is contained in a cartridge.
Note that "backup" printing mode mixes colours, to produce "black", because the "black" ink-cartridge has failed.
So, replace the BLACK ink-cartridge.
Jan 05, 2010 | HP Photosmart 8150 InkJet Printer
Why is it printing using ink-backup printing mode?
Because the "colour" cartridge is empty, the printer is working in "backup" mode -- rather than NOT working at all.
Replace the empty cartridge.
Dec 08, 2009 | HP PhotoSmart 7960 InkJet Printer
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
Feb 15, 2008 | HP 83 3-ink Black UV Cartridge Multipack...
HP Deskjet 2360 InkJet Printer Logo
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
