Third paper drive is not lifting papers.... - Office Equipment & Supplies
Posted by aapkliye_87 on
digivisionm
    New Friend:
  • 40 Answers
Tell me the printer model
Posted on Aug 15, 2010
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
Oct 04, 2017 | Minolta Office Equipment & Supplies
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
Panasonic dp 6030 copier error code e02-10
E2-01 sounds like a tray 1 lift malfunction. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, This usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes, the paper can fall back causing the gears to break. We normally replace the whole lift motor assembly.
If there is more then one paper tray, you can pull tray 1 out, (the code should not appear with tray 1 open. You can at least use the manual feed to keep them going until you can get the part.
May 05, 2011 | Panasonic Office Equipment & Supplies
I reloaded the paper tray. Now it says "no paper pick-up, even though I have 2 trays I can get neither to work. I have tried nv ram. The printer is only 3 months old and I can see nothing wrong with...
Check under the paper tray, paper lift has to be act with the help of "knoch"( a small plastic part along with the spring to lock the paper lift) while loading the tray. If its broken or nor functioning properly paper wont lift to pickup, result error shows reload the paper tay, if "knoch" is good chek under the tray there is a metal frame drives the "knoch" If its not connecting properly make the frame slight bend to ward to up side at the centre pont. load the tray and observe whether paper lift acting or not. .
Best of luck..
Vinay.Hyderabad.
[email protected].
Apr 18, 2011 | HP Laserjet M2727nf Multifunction Printer
It keeps coming up saying add paper, but there is paper in it
First, you need to verify if the paper cassette is lifting.
When you push the cassette into the copier,
can you hear the lift mechanism raising like the other trays?
If not, you have faulty lift drive unit.
Mar 23, 2011 | Toshiba e-Studio 350 Copier
Please advise what you charge for solving following problem:\r\n"Paper jam on Brother MFC-260C:Following Brother User's Guide, I removed the Jam Clear Cover, and pulled out jammed paper, but got only...
1. Unplug machines power cord from the power outlet. 2. Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position. 4c89ecbe03c0173ae1000000cd8620c6.gif 3. Remove all of the paper scraps stuck inside the machine. NOTE: The print head can be moved manually with hand to assist with removing all of the paper scraps. 4c89ed1103c0173ae1000000cd8620c6.gif
4. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper. Then close the Jam Clear Cover (1).
5. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
6. Remove the paper tray from the machine.
7. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
8. Using your hand, lift the front of the machine approximately 6 inches off the surface.
9. Look inside the tray areas roof of the machine and you should see a row of black rollers. See picture below.
10. Look in-between each of the black rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
11. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
12. Place the machine gently down onto the surface.
- If paper scraps were found and removed from the machine, continue to STEP 13.
- If no paper scraps were found inside the machine, the paper in the tray may be causing the issue. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper must be replaced.
- If you do not have replacement paper, follow the rest of this solution, after you have replaced the paper.
- If you replaced the paper, continue to STEP 13.
13. Put the paper tray back into the machine.
Dec 18, 2010 | Brother Office Equipment & Supplies
THE DRIVE GEAR FOR THE PAPER TRAY IS BROKE
The gear drive is located in the paper tray lift motor assembly. The gears teeth strip away with wear and tear and can no longer lift the tray to feed paper. Replace this assembly and not just the gear.
Oct 14, 2009 | Ricoh Aficio MP 161 Black and White Copier
I have a Toshiba 3560 copier. Its stating 'CASSETTE OUT OF ORDER' Any suggestions on getting this beast up and purring again?
Either there is paper trapped behind that cassette preventing lifting mechanism from lifting paper up to feed height.....or the lift drive assembly has failed. Pull the tray out until it stops, then lift front side of cassette to release/remove it. Look into opening towards right. If no paper, turn copier off then on....this should clear the 'cassette out of order' message. Now, reinstall your cassette. Make sure there is less than approx. 1/2 inch of paper in cassette, then insert cassette fully. It should attempt to raise up....if you hear popping noise during lifting process, the lift drive assembly needs repaired.
Sep 15, 2009 | Toshiba Office Equipment & Supplies
C0910 code im3520 imagistics copier
Your lift motor, for second paper tray draw, or third draw, are you storing extra paper in the second or third draw, beside the paper properly placed in the draw. Is there paper behind the draw? Do not store extra paper in a paper draw. Just because the draw has space not setup for 11x17 paper and is being used for 81/2x11 dont store extra paper. If this is a large capacity tray for over 500 sheets paper can only be set up for 81/2x11 protrait not landscape.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 06, 2009 | Office Equipment & Supplies
Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Jan 09, 2009 | Brother HL 5250DN Laser Printer
20 people viewed this question
Marvin
Marvin
