Question about Samsung SyncMaster T200 LCD Monitor
Problem with Samsung SyncMaster T200: After the monitor loses signal from the computer (for power saving by the computer or when it turns off), turning on the computer or bringing it out of power saving mode, the monitor doesn't respond. It's red light blinks normally with an additional half a blink in the middle and sometimes the screen flashes. Pushing the 'source' button, turning it off and on or plugging it into another computer doesn't help. Also, all the cables are strongly connected on both ends. The problem appears and disappears at random (it begins searching for source until it finds the computer's signal) doesn't matter if the computer is on or off.
Posted by or_avrahamy on
  • rl_noob
    rl_noob Mar 19, 2012
    can someone expand on solving this? I have the same problem and a brand new dvi cable didn't help. I don't know if vga is required to fix it, but either way, my computer doesn't have a port for it.
  • rl_noob
digivisionm
    New Friend:
  • 40 Answers
Try with new vga cable
Posted on Aug 15, 2010
Settings for reading
HI USR THIS LINK http://www.cnet.com/products/samsung-syncmaster-t200-lcd-monitor-20/specs/
Feb 23, 2015 | Samsung SyncMaster T200 LCD Monitor
Monitor SyncMaster T200 has no image, but LED is blinking. What to do?
That model uses the same power supply board as the Samsung Syncmaster 2053BW and here is a link to a repair guide for that model that should get you going on the right track.
http://www.ccl-la.com/blog/index.php/samsung-syncmaster-2053bw/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 15, 2012 | Computers & Internet
I want to ask how to open case on SyncMaster SAMSUNG T200 monitor 20'
Its sitting around snapped first remove the hoof and look for some screws to find open with a putty knife or very flat tool, but beware the cap has tabs that must be slowly loosened otherwise they will break.
Aug 26, 2010 | Samsung SyncMaster T200 LCD Monitor
My samsung 750s monitor has a message saying sync. out of range
When you turn off the pc the monitor loses the sync signal and should go into a suspend mode where the screen is blanked. The power management settings should be checked. In display properties check that the monitor is installed correctly.
Jun 06, 2010 | Samsung SyncMaster 750S Monitor
SyncMaster T200 won't respond after turning it off and back on.
i also got this problem..
do you have the switching anolog/digital thing?
that he doesnt know which he(t200) needs to pick?
Feb 05, 2009 | Samsung SyncMaster T200 LCD Monitor
Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
Dec 28, 2008 | Samsung SyncMaster T200 LCD Monitor
After few minutes I have disturbance in picture on SM T200
i have almost the same problem and can't find a solution... hopefully the guy who made my computer know whats wrong with it...
my samsung syncmaster is also connected to the DVi port(digital)
and it's sometimes working for a day and other times for a minute of 5.
and now i get it always in games what i get is:
-screen go black and in the top left corner yuo see analog(VGA port)and then digital(DVI) again.
and this will continue for at least 5 min sometime it stops after that sometimes never and i need to reboot(1of 5 times that work sadly)
-i get a buzz sound while he is doing that.
-sometime i get a green flash in the shape of what i was doing and then he change again.
can anyone help me/us?
Dec 20, 2008 | Samsung SyncMaster T200 LCD Monitor
Samsung syncmaster t200 volume
there are no speakers on it, how could u take sound?
Oct 21, 2008 | Samsung SyncMaster T200 LCD Monitor
Samsung SyncMaster T200 LCD Monitor Logo
1,051 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
