Raise the motor all the way up and lock the support mechanism in place. As you are looking at the back underneith of the motor, you should be able to see the three trim/tilt rams. Just to the right of the center ram, you should be able to see a plasic cap about 3/4" in diameter. Unscrew the cap and fill with power tilt and trim fluid (you can also use dextron II or III) until it is filled to the bottom edge of the hole. Put the cap back on. Run it up and down a few times, then check it again. You may have to add a little more fluid if you had some aid in the system.
Hope that helps.
Mike
Hope that
