Question about Pride Mobility Products Health & Beauty
I need a wiring diagram for a mini Jazzy 1143 power chair. The controller cable was chewed in two by a dog and ther seems to be more wires than connection points.
Posted by dale_kremer on
lennieg2000
  • 692 Answers
I think it would be easier for you to contact pride mobility or your provider and have then send you a new cable. If Medicare purchased your chair then they will pay for the repair Hope this helps
Posted on Aug 17, 2010
well if u need the charger on then batterys are dead and need to be recharged,or have the batterys checked make sure they are ok by testing a load on them at a local auto parts store for free,if no good make sure u get same type of battery and make sure it is a gel battery not a acid battery
Sep 04, 2013 | Electric Health & Beauty
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
I do volunteer work for a non-profit organization in Milwaukee that recycles donated power wheelchairs, scooters and other medical equipment. I have been tasked with finding and printing battery...
Hello mmcpowers,
For the Pride Jazzy wheel chairs you can locate what you need at the Jazzy website at the following link http://www.thescooterstore.com/products/product_manuals.aspx
When on the site you will locate the chair you need and the wire diagrams are in the owners manuals. As a common problem is just a plug coming un-wired they tell you where they are and the wire configuration. If you tell me some of the other chairs you are dealing with I will try and locate the website for them as well.
Thank you for choosing FIxYa.com
Jan 10, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Inside wiring got chewed up
the hanes jeep manual located at any autoparts store for this model cherokee comes complete with full detailed wiring diagrams, if you're lucky you can find one cheaper on amazon or ebay but they're very usefull for small repairs and troubleshooting!
Aug 07, 2009 | 1994 Jeep Cherokee Country
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Go to turn the power on the controller of a Jazzy 1143. The lights on the controller flash and no power goees to the chair. Have checked all connections and still nothing works.
Flashing lights indicates a fault. Here' the users manual which contains the fault codes for the flashing lights. Repost with more info re: the fault codes. Good Luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jazzy_1143_om.pdf
Also, make sure the charger is not plugged into the chair.
Jun 06, 2009 | Pride Jazzy 1113 Power Chair
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Apr 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1200 power wheelchair is electrically inoperable after owner fell on back of chair at night. Battery was charging at time of accident. Believe problem may be in multi-pin connector betweenjoystick...
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Mar 07, 2009 | Pride Health & Beauty
Health & Beauty Logo
297 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
