Question about Danco Faucet Stem
Where does the spring and rubber piece go when installing a Danco 2S-2H/C stem?
Posted by dan_schout on
Anonymous
    New Friend:
  • 70 Answers
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
Replaced faucet cartridge but can't seat stem properly
It sounds like you might be missing a part. Check your list for all included parts. All parts are critical.
Sep 03, 2017 | Danco Faucet Stem
Valley 3Z-6H/C
Put the large part of the spring into the plastic or rubber washer first, then insert into faucet. I use a little of petrolem jelly for easy instlation.
Dec 22, 2013 | Danco Faucet Cartridge
How do you replace the old stem with the new one that has the additional parts of black rubber piece and spring/white plastic? I cannot get those pieces to go on and still reassemble the handle.
If the new parts don't resemble the old ones
they shouldn't be used,your wasting your time.
Take the old parts to a quality plumbing store
where the pros go and get the correct help
and parts
Jan 31, 2011 | Danco Faucet Cartridge
How do the 3 pieces go together for installation. The 3Z-6H/C?? thanks
first off, put the spring in the faucet big end down. then put the black rubber boot seal in next and push it into place. Then place the Stem in but be sure to line up the notches before you screw it all down. I hope the will help you....
Jan 07, 2011 | Danco Faucet Cartridge
I bought the Danco replacement stem for a milwaukee faucet(part 4s-6h/c) it is leaking from the handle... do I need to replace the plastic part that runs back into the pipe? Is there an easy way to remove...
Sometimes on the stems on the side the handle attaches is a nut that can be tightened. Inside this nut is a rubber or other type of seal. tightening this nut stops the water from coming out of the handle. If the nut has already been tightened then possibly need to replace this rubber seal.
Sep 02, 2010 | Danco Faucet Stem
Where does washer go for 12h-6h/c stem from Danco for faucet?
Is it brass, stainless, plastic or rubber? I think a stainless one might be for the knob screw, I don't think there is one inside, it might just have fallen into the pack. We get weird stuff all the time that doesn't belong. Hope this helps.
May 31, 2010 | Danco Faucet Cartridge
How does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Apr 08, 2009 | Danco Faucet Stem
How to modify Danco handles to work on Valley II faucets
Do not modify the handles, just buy the pieces missing. they are available through Danco. Even though i prefer using original parts.
Jan 10, 2009 | Plumbing
Danco Faucet Stem  Logo
778 people viewed this question
Top Danco Home Experts
john h
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
