Question about Sony KP-53V80 53" Rear Projection Television
I was playing with the remote, now tv won't turn on, have I put it in some sort of "locked" mode?
Posted by rodkaren on
Anonymous
    New Friend:
I had the same problem my 4 year old soon played with the remote and not more TV.
Posted on Aug 16, 2010
Electrohome tv in lock mode and won't reset
Your answer may be in this document: http://electrohome.com/discontinued/manual/27E404_Eng.pdf
Aug 07, 2012 | Televison & Video
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
Inside trunk release won't open trunk on 2002 Camry. Lock will not turn with master key. Remote trunk opener will open trunk.
1. Open trunk
2. Place latch in lock position
3. Pull inside trunk release to see what isn't moving
4. If trunk key won't turn, the key may be worn out and need to be replaced
Jun 05, 2011 | Toyota Camry Cars & Trucks
Key lock on my lg tv
Sounds like its been put into Hotel Mode. This is a mode normally found on Tv sets that are installed into Hotels Hense the Name this Greys out a lot of the tuning option on the Tv.
Give this ago and see if this will sort you out. Before I go any further be very Carefull in this menu as this is the hidden LG installer menu and I do not want you to brick you telly.
Hold down the menu button on the remote for Approx 5 seconds then type in 1105 This should bring up the hidden installer menu so that you can check that the Hotel mode is not set to on. Make sure this is set to off as This may be the cause of your problem.
Hope this helps you sort out your Telly. If so then please leave a thumbs up.
Cheers Little Dish Fitter
Oct 03, 2009 | Televison & Video
Tv is on lock mode
Try your "menu" button on your remote. There should be something there under setup for locks and unlocks.
Good luck.
Jul 17, 2009 | Apex Digital Televison & Video
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
Sony KP-53V80 53" Rear Projection Television Logo
52 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
