Haier HPAC9M Air Conditioner Logo
Posted on Aug 14, 2010
The air conditioner doesn't cool the air much anymore. Does it need a freon charge?
5 Related Answers
Anonymous
  • 31 Answers
  • Posted on Nov 17, 2008
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Anonymous
  • 56 Answers
  • Posted on Feb 12, 2009
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on Apr 26, 2009
SOURCE: may need freon?
I would first try cleaning it out as any dust build up will decrease the ability for it to cool. Then I would go and have the freon pressure tested. Does it feel like cool air is coming out at all?
Benjamin
Anonymous
  • 340 Answers
  • Posted on Jun 19, 2009
SOURCE: mr. slim air conditioner does not cool.
maybe just a cleaning
Anonymous
  • 1515 Answers
  • Posted on Jun 08, 2011
SOURCE: My Haier portable room air
Hi, I doubt if this unit has charging valves on it as most come from the factory with out them. I am sure it will use R-134A freon, but have you checked to see if your compressor is running and not just the blower? You may have a faulty run capacitor or compressor. They should never have to be charged unless they develop a leak somewhere. You would be better off taling it into a appliance repair shop and have it checked, as they can tell you real fast what is wrong. Good luck,
Shastalaker7
A/C, Contractor
Location of freon in carrier air conditioner camper
They are a closed system, meaning they shouldn't need re-charge unless a leak has occurred, and to Have an AC repair person come and evacuate, cut lines, add fitting and re-charge, could get pretty expensive. Most people find it smarter just to buy a new unit but get an estimate on repair and decide for yourself. Why do you think it needs freon, not cooling enough, or at all?
2answers
We have a Carrier 25HBA unit and we've noticed a frost build up on the outside compressor, my husband turned the unit off and cleaned everything outside and up in the attic. It worked. No frost...
Hello
Frost or ice on the bigger outside copper line is a indicatin of possible low freon.Hopfully that is all it is.
It is also a possibility the compressor is getting ready to break,bad valves.
You will need a tech to come out and charge the system with freon.
Check your filter is clean and new first.
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
The air conditioner isn't cooling. The filter was dirty so I cleaned it and it still doesn't cool. Any ideas for trouble shooting? Please help! Thanks!
Hi, if this is a wall or window unit, pull the plug and go out side, take your garden hose and give the condenser coil a good washing out. Be careful not to flatten the aluminum fins, this is important. If the coil is dirty, it will cause the freon pressures to be very high putting a load on everything, and it will not cool. If this does not do it, you may have a weak compressor with bad valves, not pumping, low on freon from a small leak, and you would have to call a tech to repair and charge it. Hopefully the coil is dirty and this will cure the problem.
Shastalaker7
A/C, Contractor
1helpful
AIR DOES NOT SEEM TO BE COOL ENOUGH LAST YEAR HAD SERVICE COME AND PUT FREEON IN
hi,
If the the AC doesn't get the cooling then the main reason will lack of freon gas.
Is the fan works perfectly. Also check the fan is it working perfectly. If the fan is ok then you have to refill the freon gas again.
ok
My panasonic in wall air conditioner doesn't cool anymore --
Hi, if your 6 year old Aircon has not yet been re-charged eversince it was bought, then yes it's time for a refrigerant re-charge.
I hope it helps.
1helpful
1helpful
Not cooling properly
EVERSTAR MODEL 10CR-1NOT COOLING CLEAN VENTS, STILL NOT COOLING.
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
