Remote control sensor doesn't work when the room is dark.
I have a Time Warner Scientific Atlanta Explorer 3100 cable box that doesn't respond to the remote control when the room is dark. Daylight, overhead light on, the box works fine. But when the room is dark, the box will not respond even when the remote is very close. I can even shine a flashlite on the box simultaneously with the remote and it will work at night.
I don't intend to fix this box (rental), but it confounds me as to why this happens.
Posted by Ryard on
Russ Hill
  • Televison & ... Master
  • 4,057 Answers
Its probably the led in the remoter, check with a camera on a phone point the camera at the remote if its dim, that's the problem, it could also be a damaged battery in the remote.
Posted on Jun 18, 2017
5 Related Answers
nywarrior
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
Anonymous
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
there is no "code search" button on the RCR3273???? can anybody help?
Posted on Aug 31, 2008
Anonymous
SOURCE: how to connect a Time warner cable remote to the tv
I made mine work by using programing the vcr button as opposed to the tv.
Posted on Dec 23, 2008
Anonymous
  • 6 Answers
SOURCE: Scientific Atlanta Explorer 8300 says ''EXPLORER not AUTHORIZED
The message is so cryptic...it's right. There is no way to unblock it yourself. This is the box connecting to your cable company's servers and being told that, "no, you are not allowed to access content, disable yourself." It is referred to as "bricking" as the box is now as useful as a brick.
If the box worked previously and all-of-a-sudden this happened, then it could be that there is a typo in your account, and your cable company can correct it quickly. It could also be that your bill is past due and needs to be paid. Generally if it's a past due issue, a payment will reactivate it instantly.
If you are not paying for digital service and you bought this from eBay or got it at a flea market, then you'd need to add service and add the box to your account. The problem is your cable company might not like one box reappearing on another account--it seems stolen. They may just want the box back, and give you another that would work.
Posted on Jun 10, 2009
Anonymous
SOURCE: Use Yamaha Remote to Control Scientific Atlanta Explorer 8300
I want to know the same thing.
Posted on Jan 17, 2010
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
Looking for 'Scientific Atlanta Explorer 4250HD' code for Jumbo URC-152 remote
Check these codes. 004/ 009/ 172/ 175. If you wish to get four digit or five digit codes, check this link.
Feb 19, 2013 | Televison & Video
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Change default channel on cable box
Called the cable provider, Time Warner, and used the "settings" menu to navigate to power on channel, where I selected the default channel.
Nov 13, 2009 | Atlantic Scientific Network connector
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Need codes for on for all universal remote.
i have a sharp 42" lcd tv and i need the remote code for the time warner scientific atlanta new york city cable box on the sharp remote
Nov 21, 2008 | Sharp RRMCG1687PESA Remote Control
How to connect a Time warner cable remote to the tv
Aug 21, 2008 | Sylvania 6520FDE 20 in. TV/DVD Combo
Code For Scientific Atlanta Explorer 1840 Cable Box
Try this first:
1. Press and hold SELECT and CBL until all mode keys blink twice.
2. Press 9 7 7. All mode keys blink three times. Then, after a few seconds the CBL key
blinks twice.
This put's the remote back to default. If you need more help let me know.
Jul 09, 2008 | Sony RM-V401 Remote Control
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote codes
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Symphonic TV & Scientific Atlanta Explorer 2000 cable box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Dec 21, 2007 | Symphonic ST419E TV
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
