Question about Toshiba E-Studio 3511 Color Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Posted by gemini09 on
Anonymous
    New Friend:
  • 30 Answers
Hi how are you this is jack ... [email protected]
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Posted on Aug 15, 2010
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
Where is waste toner located in copier
In the past i have found the waste toner bottle is usually the same place as either the toner or the drum (mostly the drum) and will be a clear bottle. Possibly wide at the bottom and thinner at the top.
Hope this helps
Nov 07, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Where to replace waste toner on Imagistics copier
You don't have to replace the waste toner bottle at all. It's located on the lower right side of the copier. Remove the two screws and cover. You should see a plastic bottle there and remove it and dump the contents in the trash. Most of the time the bottle isn't even close to be needing to be empted. The copier has a counter for waste toner and when it gets, I believe over 250,00 copies, it displays to empty the waste toner. You should reset the counter after emptying the bottle. You do this by pressing the addtional function key, then the 2 & 8 keys at the same time, then the additional function key. This gets you into service mode. Be careful here, it can get you into real trouble if you don't know what you're doing. Press copier, then counter at the top right, then MISC, then wst-tnr, then " C " on keypad. The counter should go to all zeros. Press the reset button several times and you should be all set. Good Luck.
Dec 28, 2010 | Canon imageRUNNER 5570 Copier
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
Nov 10, 2008 | Office Equipment & Supplies
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
292 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
jasbo
jasbo
CheckitRight
CheckitRight
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
