SOURCE: camcorder not working properly
Hi lisa, Your ccd imager needs replacing, inherent fault with original item, contact local JVC dealer, will repair free of charge. Ed
SOURCE: JVC compact VHS camcorder will not record.
i'm sorry i dont have a suggestion, but i do have a problem with the focus on my camcorder everything works except the picture on it. and i've bought the vhs-c vcr converter tape to go with it. i would like a manual for it and cant seem to find the right sight to print off a manual
SOURCE: camcorder says lens cap is on when its not
No Prob...I had the same problem with my GR-D72U. There is a defect in the CCD
image sensor. JVC will fix it for FREE! All it will cost you is shipping it to
them. Go to http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D72US&Pgm=CCD
, download the rapair request... Send it off to your nearest service center and
they ship it back all fixed up in less than a week. I must tell you though, you
ONLY have until Dec. 31 2008 to do this. Not only did they fix mine, they
cleaned the heads but also buffed out a scratch. After you get yours fixed, post
as many helps as you can to others.
SOURCE: E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
SOURCE: JVC GR-D90U Camcorder. the LCD screen and eyeviewer wont FOCUS!
Its need to replace ccd base assy
