Make sure that you are charging the chair 12-14 hrs before driving. charge with the joystick on, make sure both freewheel levers are in locked position.
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
try holding the on off button till you hear a beep. then push the joystick forward and hold till beep then pull back till you hear a beep. you should be locked, then repeat to unlock.
Hi. The answer depends on what brand of controller you have, Dynamic or VSI.
Try this.
Push on button to turn on machine.
Push the joystick to full forward until it beeps.
Pull joystick to full reverse until it beeps.
Release the joystick. There will be a long beep.
It should now be unlocked.
Hope this helps. Neil.
