Microwave Ovens Logo
Posted on Aug 14, 2010
How do you change the bulb inside in a GMC275, GMC305 Microwave?
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 08, 2010
SOURCE: How do I replace the light on a Whirlpool Gold
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
2answers
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
How do I replace the light on a Whirlpool Gold Microwave GMC275 or GMC305? Thanks for your help!
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
LIGHT INSIDE OF OVEN NEEDS REPLACING --HOW DO I GET TO BULB
normally there is a side door that can be removed to replace the inside light bulb, the microwave bublb is changed from a different location normally on the back.
Can the light bulb be changed in this model?
Normally a microwave has to be opened to do this , very high voltage inside approx 2400v , but a normal screw in microwave bulb.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
