Question about HP DeskJet 920c InkJet Printer
The Pc acknowledges the printer it tries to print and then gives up
Posted by pamo681 on
Cannon MP492 printer not acknowledging my doc to scan
But, you can print?! When you scan to PC the page is blank?
Hp C6180 all in one will not connect to wireless laptop
when the printer is on is there on your pc/laptop a wifi signal checking your wifi signals. then using the wifi code off the printer put the code in and connect. and then the printing should be allowed. and that laptop/pc is the controler. i had to do this with mine and its been fine since.
I contacted HP for my printer problem and they told me it is a windows problem. I have a Nobilis computer so microsoft wouldnt help. My printer is acknowledged in the computer, however the printer spooler...
Try to re-install the printer driver as it may be corrupt, most of the time this fixes the problem. I hope this helped. Good luck and have a fantastic day.
Why when i press print on my pc does it come up with could not get printer information,is it my pc or is it the printer?
It could be the cable(USB) from PC to printer. Check that out first. Remove & reinsert with the PC running & if it acknowledges then printer is OK. Reinstall printer drivers.
I printed two pages, and now my printer will not acknowledge there is paper in the tray and it just doesn't catch, so nothing will print.
Power cycle the printer
Try printing again
If it does not work
Print a test page from the printer itself as stand alone
if it does not print
It could be a hardware issue
check also ink levels if they were low
We can give you specific answers if you can post exact model of the printer and its brand
If you can print from the printer itself without the help of the computer it means the issue we need to settle is the connectivity
is it usb cable?wired? or wireless?
if printer lost its connectivity with the computer it will defnitely not print
either restart the computer,check cables if they were plug correctly,reconnect the printer wirelessly to the pc.
Hope I help you a bit
HOW TO PRINT FAX ACKNOWLEDGEMENT IN PANASONIC KX-FLB802
MULTIFUNCION PANASONIC KX-FLM551/FLB751
FAVOR ENVIAR CORREO A [email protected]
Gracias
No communication between computer and laptop
I don't know which Op system you have, but you will need to look in your printers folder or on control panel printers and faxes and click on your printer>then cancel all documents. You may need to do a simple reset which is to uplug the printer from the power source, open the door where you clear paper jams and give the paper roller a gentle push forward until it clicks. If neither of these options helps you, you may need to reinstall the printer drivers.
Brother MFC5440 Does Not Print
A1: close scanner (this is NO error!)
Take carts out and reinsert. Make sure they are secured. Watch display and give answer (Cart changed? 1: YES).
2answers
Lexmark Z33 Cable Problem
hi dear
trying to change port of usb where your connect, or try to change your USB cable
oke
HP DeskJet 920c InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
