When you hook up to the computer I created a folder called JAVA, and downloaded anything thats java into that folder...then using the phone I opened that folder and installed....it automatically links to the Java button in the first screen and you can use it. Took me a while to figure it out.
Do you know how to set it up so when I get calls or messages I see the name of the person and not the number? Thanks
SOURCE: installing java applications and games in razr v3i
download your .jar files to ur pc....
then copy and paste them in the kjava folder on your mobile.....
then go to games & apps and click menu and select switch storage device...
when you switch ovr to memory card ul find "Install New" click on that and u shud have no othr problem....
was it helpful????
let me know
hey first of all you need a .jad file for all the java files.
download jad maker from here
http://www.brothersoft.com/jadmaker-25179.html
drag and drop the java files to the jad maker window to create a jad file for that particular java file.
once you're done copy both the java and jad files to the "other files" directory on the phone.
Now exit all menus and type in this code: *#9998*4678255#.You should now get a 'Activated' message. [This is to enable java installation.]
Then go to the other files directory where you placed the jad and java files. Open the .jad file and then click install.
Once the installation is done you can disable java installation by re-typing that code again.
SOURCE: i cannot install java applications in my nokia3110c
dear,
your phone is java supported so it much accept java application.
you need to get .jar file from any site like "getjar" or else...
go ahead. if it says same like before then u need to update the firware for this...
good luck....
SOURCE: how to install java application in satio
Please check what is version of java application you are trying to download on sation as satio dont support few versions
