Cell Phones Logo
Posted on Aug 14, 2010
All folders in pen drive become shortcut - Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on May 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
29843
Points
48
Your pen drive probably was infected with some some kinds of virus or trojans. See this blog article how to fix file folders shortcuts problem step by step. Hope it helps. Regards
1helpful
3answers
My external hard disk has been infested with viruses and files and folders made shortcuts. how can i recover the files and folders?
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - http://www.shortcutvirusremover.com
Place it in your pen drive and double click to run. Press Enter to confirm its process. That is all. Shortcuts will remove and your data will be back in a second.
Processing is very slow
it seems your computer or the pen drive or both virus infected.
press win button + R - type cmd - type H: (if your pen drive recognized as H or (whatever your pen drive's drive letter)
then carefully type the following without bracket [attrib -r -s -h *.* /s /d]
press enter. now check your pen drive. if you could not, inform me i'll give images with explanation
3helpful
2answers
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
1helpful
2answers
All folder can't open..shortcut virus
See the video which explains how to remove short cut virus..
2helpful
All my file become shortcut folder in my pen drive how to solve it please help me
If you did not format your flash drive, then check whether the files are not in
hidden mode.
Click on "Start" -->Run-->type cmd and click on OK.
Here I assume your pendrive as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
Note : Replace the letter g with your flash drive letter.
Now check for your files in Pen Drive.
After that, download the Malwarebytes' Anti-Malware from the below link
http://en.kioskea.net/download/download-105-malwarebytes-anti-malware
Update it --> Perform "Full Scan"
Note : Default selected option is "Quick Scan".
If there are really important files in your pendrive and you need it then:
convert full pen drive to .rar --->extract each file individuly on ur hard disc. IT WORKS
. i recoverd my full data.
n den format ur pen drive.
164helpful
8answers
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
2helpful
2answers
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
Creating shortcuts of folders in my pen drive and I am not able to delete them as the shortcuts are again coming after deleting
If you are using windows 7 or vista.....just insert your usb drive in your computer then there will appear "SCAN AND FIX" window.
Now click on scan and fix.....
your shortcut error will remove from your usb drive.......
Due to virus folders in pen drive become shortcut files why? and how can I solve the problem?
Why? Because that's what the virus is doing, maliciously.
Update your computer's anti-virus.
Or, better yet, UNINSTALL it (it may have been sabotaged/compromised) and install anti-virus software by downloading from: http://www.microsoft.com/security_essentials
Install this software. As the final step of the install, choose "full" anti-virus scan, and also select the drive-letter for your pen-drive, so that it also gets scanned for malware.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
