Question about Denon DVD 2930 DVD Player
I've got a Denon 2930CI DVD player. Recently, it stopped playing most CD/DVD (Audio and video). When it was new it was great, but it started taking fewer and fewer disks, and now it is rarely able to play at all. Even when it is able to read the disk, i.e., it displays the number of tracks and total time, it does not play, just show track 1 0:00, and that's it. I'll appreciate your help.
    New Friend:
Hi, If anybody knows how to resolve the following message(Denon DVD 2930)"This disc cannot be read on the DVD player" please send me your secret!!
Posted on Nov 16, 2010
    New Friend:
Change the optical unit (laser)
Posted on May 07, 2012
6ya staff
SOURCE:
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
DENON DCD-825 CD PLAYER stopped playing
Mine did the same and I cleaned the laser lens and it cured it
May 22, 2008 | Audio Players & Recorders
DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
Jan 23, 2008 | Denon AVR-1803 Receiver
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Denon DVD 2930 DVD Player Logo
525 people viewed this question
Top Denon Televison & Video Experts
Ekse
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
