Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have 3 pendrive first & second pendrive of transcend & croma is not recognised pny 4 GB pendrive it shows (please insert a drive into F)
Posted by hozefasham on
Kiran Anto
  • 420 Answers
try using this software to format the transcend pendrive . use it in XP or Vista www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Posted on Sep 10, 2010
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
My trancend 8gb pendrive when inserted dont show name of transend
Dont worry much about that, it's the way your PC recognises the device. you can rename the drive if you want in my computer
May 06, 2010 | Transcend (589307) Media
Showing an error ''insert a disk in removable media''
Its happened for my Transcend 4 Gb pendrive. I format dat using ONLINE RECOVERY TOOL from Transcend. Now its workin :-) :-) :-)
Dec 16, 2009 | Electronics - Others
Pny pendrive 4 GB
this happens when the pendrive chip becomes faulty, replace the pendrive
Sep 17, 2009 | PNY Technologies GeForce 6200 128MB AGP...
When pendrive is connected shows device has malfunctioned
when i connedted my pen drive i show has malfunctioned
Dec 14, 2008 | Transcend (589307) Media
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
170 people viewed this question
Top PNY Electronics - Others Experts
Marvin
Marvin
Jax Planet
Jax Planet
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
