If you could use another computer which could download from Internet, you can create a windows password recovery disk. Third party software windows login recovery could create such a disk. Only four steps:
Step 1: Download Windows Login Recovery and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
Firstly, use password prompt function on password locked computer
If you have set the prompt option when you set account password, it
may help you remember something about your forgotten computer password!
Secondly, reset computer password with default administrator account
Once we install Windows OS, there will be automatically generated an
"Administrator" account with blank password. Therefore, if we forgot
password on computer, we can have a try:
a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
c. Recover computer password by: Control Panel - User Accounts.
Thirdly, find computer password with computer password reset disk
If we created this computer password reset disk before we forgot
password, we can opt for the disk to help us unlock password
efficiently.
a. Click OK and close the message box on the password incorrect prompt window.
b. Click "Reset Windows Password" and insert the password reset disk.
c. Do as the "Password Reset Wizard" to create a new password.
Fourthly, change computer password with Windows Installation Disc
Take computer Windows XP as example:
a. Start computer using Windows XP Setup CD.
b. When it asks to repair our current Windows installation, choose
"Accept" it and press "R" to run the repair. Then computer will begin
to repair our Windows and copy files to hard drive.
c. Setup will reboot system. Please don't press any key when there is "Press any key to continue..."
d. Now computer will do other tasks and there will be a progress bar
displayed. Please notice carefully the details shown at the bottom of
screen.
e. Once "Installing Devices" comes up, press keys: Shift+F10. Input:
nusrmgr.cpl and press Enter key at the Command Prompt window.
f. The same "User Accounts" window will display as it is in Control
Panel. Choose "Administrator account" and select any account listed to
change or remove your computer password.
Fifth, break computer password by DIY a password recovery disk
If the above four methods still can't help us reset lost computer
password, we can refer to this way now. DIY a password reset disk after
forgotten computer password means that we burn an .iso image file from
Windows password recovery software into a bootable CD/DVD/USB disk.
Now, take one of the top-rated Ainorsoft Windows Password Recovery
Corporation as example:
a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
b. Burn an ISO image file to CD/DVD/USB Flash Drive
c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
d. Reset forgotten computer password to default Re123456.
The above ways on forgotten computer password reset are the collections of best bet for us to unlock lost computer password! So even if we forgot computer password, things will be OK soon!
source: http://www.windowspasswordrecovery.net/article/forgot-computer-password.html
Are you missing the Windows password or the bios password?
