Sony KDF46E3000 46" Television Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kdf-46e3000 turns on stays on for a few minutes shuts off green power light flashes then goes to red flashing lamp light hit the power button again process starts all over. Picture looks great for the few minutes that it's on. Is it the lamp or do I have another problem?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955304
Points
33084
It is the lamp that is reached at end of life span.
Replace lamp in tv if it has not been replaced in last 2-3 years.
Lamp replacement procedure is easy and written in user manual.
2helpful
Blinking green light
Try cleaning both fans and inspect the lamp. Usually quite obvious if the lamp is bad (ie. blown tube/shattered glass) Make sure you secure the lamp door properly after.
1helpful
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
2helpful
2answers
Sony KDF-E50A10 stays on for 15-20 minutes then shuts off power standby light flashes green and turns back on. Replaced bulb about 6 months ago with sony bulb. Any ideas. Thanks
The reason this happens the most is because of the lamp being weak. I have not seen anything else cause this problem. You can varify this by turning the set off and wait until it shuts down totally.
with the Sony remote, press the display button, the #5 button,
volume down button, then power button. This puts you into the the factory error code mode. If you see the lamp code with multiple errors and no other errors shown, the lamp is the problem.
Most of Sonys lamps have a aprox life of 3000 hrs. Some last longer and some shorter.
I hope this helps,
Skyassoc
3helpful
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
2answers
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
4answers
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
