Question about Whirlwind FH-778 Air Conditioner
I have a Lennox heat pump (1994 model HP19-461-7P, SN 5894\r\nF56813) I have been having issues with. About 6 weeks with the ac running, we smelt somthing from the house like the first time you run your heat in fall. After that the ac worked fine for a day or so, then it quit working. The system is fully charged but I did find a diode burned on the defrost control circuit board. I unplugged the wire from the defrost terminal to try and disable the defrost mode thinking this may be my problem. Unit worked fine for 2 or 3 weeks, then no ac again. When the ac quits working, I check the compressor, and it will be very hot. I can cool it off with a water hose and it will start cooling properly again. Only once did I have to reset the switch to get the compressor to restart. I am ordering a new defrost control board but not sure this will fix my problem. Also I can turn off the breakers to the whole system, turn back on, and this seems to reset everything and unit starts working again. For a while. Your help would be much appreciated. Thanks.
Posted by clayton2100 on
5 Related Answers
t1m130
t1m130
  • 86 Answers
SOURCE: How old is my Lennox air conditioner?
not positive but looks like 5-8-02
Posted on Jul 14, 2009
Anonymous
  • 614 Answers
SOURCE: AMANA AC unit Blows heat in cooling mode
These valves do get stuck. They energize for cool and in the dead postion they heat. Your valve is stuck or not energized. Can you here it click or try to energize. If you dont hee the click you do not have voltage to the valve. The valve is powered thru the defrost board. So that might be your problem. If you have voltmeter. Take the two wires off the valve and turnit on cool you should get 24 volts. If you have 24 volts the valve is bad. If you do have voltage to the valve tap the valve while energized and sometimes this will loosen them up. If the board or valve is bad you will have to call a service tech. Russ There is only so much you can do.
Posted on Jul 25, 2009
Anonymous
  • 232 Answers
SOURCE: BTU of an old Lennox condensing unit and A coil
38,000 btu AKA 3 ton
Posted on Sep 20, 2009
Testimonial: "Thank you for your help! Chong1238"
Anonymous
  • 334 Answers
SOURCE: My ac unit works sporadically. Today it cooled
First check your filters to make sure they are clean and you have proper airflow.
If they are clean, then you either have low refridgerant or dirty coils.
The outside coils can easily be cleaned by disconnecting power to the unit, then using a water hose to spray off the dirt, grass, etc.
The inside coild can be very difficult to get to on some units and require a special evaporator coil cleaner. As for adding refridgerant, the Law requires one to be certified for purchasing or working with refridgerant so you may need to call a service tech for that. Expect a bill from $100 to $225 for a typical system recharge depending on how low it is and which company you call.
Posted on Oct 10, 2009
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: what size capacitor do I
Your Lennox Condenser HS18-311-7P uses a 35 MFD 370 Volt Round Run Capacitor. Here it is:
http://americanhvacparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=CAP35370R&Category_Code=c-370vrrc
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jun 18, 2011
My Lennox MS7 heat pump was installed about a year ago and hasn't had any problems until last week. It has started changing settings (like on or off, higher temperature, light on or off) without prompting...
Go to the unit locate the control module. Take wires to thermostat out. Now jump from R to Y your AC should come on. Jump R to W your heat should come on. Jump R to G your blower should come. If you have done these and it stay on or run as it should then you need a new THERMOSTAT.
Oct 26, 2013 | Lennox 7 Series MS7-HO-30P MS7-HI-30P Heat...
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 23, 2017 | Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
Change from old lennox thermostat to honeywell 5000
no offense but you need some new a.c. guys. what if they were hired to do this job, would they say they couldn't do it? we need model numbers of tstat and indoor unit to help, obviously these colors go to the same components your new tstat will control!
Oct 29, 2017 | Honeywell Electronic Programmable...
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Jul 14, 2009 | Heating & Cooling
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
242 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Paul Carew
Vincent G
Vincent G
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
