The compressor is not always starting...sometimes it tries but does not start...
It could be a capacitor and relay problem... or the compressor could be going bad...
Change the capacitor and start relay first and then see if that gets it going...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
SOURCE: Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
SOURCE: Outdoor A/C unit fan
If the fan and compressor are shutting off. its possible its cycling on a low pressure switch. probably low on freon.
or you have a low ambient kit to keep pressures up during low outdoor temps while ac is running just the fan will shut off, however thats not a typical thing to have a residential system
Testimonial: "After ohming out the compressor and fan and checking the switch, I got the neighbors gauges and found out that was the problem - Low. Thanks"
SOURCE: fan not working; no cooling
heatman101
