Question about Krups Small Appliances Espresso Machine
Hi. I have a Krups XP7245 combination espresso/coffee maker that leaks when I make coffee. This is a recent problem. It's out of warranty (of course), and I'd like to disassemble it to try to resolve the issue. All of the visible screws have been removed, but it is not coming apart. Afraid to go further (or break it). Help!
Posted by linjconklin on
paul_on_trav
    New Friend:
  • 17 Answers
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Posted on Aug 15, 2010
  • 4 more comments
  • ericPDX Oct 29, 2010
    I came to the same conclusion taking appart the Krups 7225 Automatic expresso machine. My question is where to find the replacement seal?
    Thanks
  • paul_on_trav Oct 30, 2010
    Groupe SEB, 1/ 10 Hill Road, Home bush. They sell it for $2.99 (pick up)
  • joe4486 Dec 20, 2010
    When I opened up the machine, I found the cup in the bottom of the machine. I assume I can reassemble the spring and plunger, with the cup. What sequence are they from the bottom up. The cup looks in good condition. Am I missing anything? Like why the cup fell out in the first place?
  • paul_on_trav Dec 21, 2010
    you mean with the cup the seal? Then it is just worn out, too loose and you need to replace it. The plunger can be removed from the spring/rod. The plunger has a screw on top and the rod an allen screw under the plastic ball. Remove both and it comes apart. The seal can be pushed into the hole under the brewer and reassemble the plunger, spring and rod. I loosen the entire boiler to get to the under side of the rod but it is possible to reach it without loosen the entire brewer unit. Good luck.
  • Anonymous Dec 27, 2010
    Don't bother replacing the seal just silicon it in as a new one will leak as well after a few uses.
  • makima
    makima Dec 29, 2015
    can i silicone it just with the disassembled casing?
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Error 06
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Nov 29, 2013 | Krups XP7245
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
I have krups xp7245. It just happened today after 2 yrs daily use.
These coffeemakers are not the easiest to work on, contact Krups and locate an authorised service agent in your area and run the fault by them, they will likely need to open it up to properly quote you. There are lots and lots of potential problems inside one of those machines. If you wish to look at yourself you are going to have to remove the top, sides and back covers. Side & back is one part. Even when you have it all exposed to not expect the fault to be immediately obvious, I have covers with cutouts so I can run it and look inside at the same time.
Feb 07, 2012 | Krups Small Appliances Espresso Machine
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Looking for down loadable instructions for krups xp7245
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 30, 2010 | Krups XP7230 Compact Super Automatic...
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
I have the krups espresso and caffe machine and i have no idea how to MAKE espresso (it's NOT the one below)...
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Apr 27, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups Small Appliances Espresso Machine Logo
1,548 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
