Xerox WorkCentre M-24 Color Copier Logo
Posted on Aug 13, 2010
Trying to copy photos onto color copier transfer paper paper melts. can I change the temp setting or anything to get it to print?
Whit
Level 1:
  • Xerox Contributor 185 Answers
  • Posted on Aug 19, 2010
Whit
Xerox Contributor
Level 1:
Answers
185
Questions
Helped
107636
Points
97
Yes, your fuser is the machine's oven. It does have a transparency/ OHP (overhead projector) setting.
When you shut the paper tray, the machine should ask you to confirm paper size and type. That's the time to do it.
Whit
Item, Inc.
I've got 2 Kyocera 5030's that are smearing color copies
if the toner can be wiped off of the paper then your issue is the media settings or the fuser is failing. If the image is fixed onto the paper but just "looks" smeared then it could be the drum(s), transfer belt, color registration, or cleaning system.
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
I am trying to scan and copy a photo on a special sized paper, how do I change the setting to copy from and onto a paper with the following dimensions: 61/2"x10"?
When you select to print a dialog print prompts, form there choose:
1-properties,
2-features,
3-resizing options,
4-custom
If you need more help come back.Post / thumbs / testimonial are welcome!
HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Trying to print on laser photo transfer paper, but printer seems to be too hot for it - is there any way to print on this transfer paper?
i tried to print on laser paper too but fuser is too hot. its melting the paper and getting jammed right? i got tired of printing on laser paper and converted to inkjet paper. this is much easier
2answers
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
2answers
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
